Sponsored by: DashLynx
Which Springs?
Old 10-04-2003, 12:49 AM
Onyx Z's Avatar
Default Which Springs?
I have LT's but also want to drop my car. Which springs should I get that will still have a semi smooth ride, yet still look good and resist scraping my y-pipe over everything in sight. Is there anything I can do to the y-pipe to make it tuck up more? The headers tuck very nicely, it's just the y-pipe that hangs down. If anyone has any pics of the car and the header clearances, please post them.
Thanks
Ryan
Old 10-05-2003, 12:01 PM
Moderator
jimmyblue's Avatar
Default Re: Which Springs?
The least drop will be with Hotchkiss and the
SLP Eibachs, both of these are nominally 3/4 -
1". Both seem to be popular & don't see people
complaining about ride or handling with either.
The way to get the tightest hang on exhaust is
to loosen the clamps / joints, put shims at every
close pass (bits of 1"x2" taped to the pipe would
ensure 3/4" clearances, something thinner if you
choose) and then put the floor jack to the low
point (more jacks = better) and jam it up to the
point of minimum clearance (seen by when you start
to lift the body) and then tighten up the joints.
Let it go, take out the shims, et voila!
Then go for a hard drive and see if you missed any
shoulda-shimmed spots....
Old 10-05-2003, 08:39 PM
Bad Blu Formula's Avatar
Actually the BMRs lower your car the least. My Hotchkis springs have actually lowered my car more than an inch, but its perfect. Ryan, you know how my car,my dad's, and Hendrik's car sit so you make the decision if you want to join the club.
Old 10-05-2003, 09:32 PM
Onyx Z's Avatar
I was thinking the Hotchkis springs so that's probably what I'll go with. I guess I'll join the club. I've heard of the Pro-Kit riding kinda rough too.
Ryan
Old 10-05-2003, 11:06 PM
Artic96V6's Avatar
love my hotchkis
Old 10-05-2003, 11:14 PM
Onyx Z's Avatar
How is the y-pipe clearance for those of you with Hooker LT's and the Hotchkis springs?
Ryan
Old 10-06-2003, 11:50 AM
Xsta Z 28's Avatar
Any spring with a 1" or less advertised drop should work well.
Hotchkis look good, and I like my SLP Eibachs . . .
