Please critique my build sheet - TSP please read
Old 01-18-2009, 07:21 PM
grind4it's Avatar
Default Please critique my build sheet - TSP please read
Ok, I am looking for some feedback before I order my parts.
A little back ground:
I am building a 1985 C4 corvette with a LS1 and 4L60E. My LS1/4L60E come by way of a wrecked 2001 Z28 with 60K miles. This will be a weekend car that will not spend anytime at the strip or track. I plan on having A/C and want the car to reliable. The only action this car will see is from a rolling start (30 – 70 mph).
Here is what I am thinking:
Stock bottom
243 Heads with lightweight valves
ARP Hex head bolts
The factory LS1 rocker arms (off my LS1)
Factory length rods
GM LS7 lifters
factory head gaskets
TSP Torquer V2 cam
LS1 Double roller timing set
Ported LS6 oil pump
LS6 intake
Coolant crossover pipes
160* Thermostat
Full length headers
Full flow mufflers (no cats)
3500 stall torque converter
Any thought on injectors, throttle body and MAF or will the factory 2001 F-body parts work?
Any guessestimates what kind of RWHP I will get with this setup?
Anything I should change?
I am planning on ordering my parts from Texas Speed and Preformance.
Thanks,
Old 01-18-2009, 10:46 PM
CalSpeedPerformance's Avatar
If you are looking for TSP to read, I suggest calling them and discussing it on the phone.
Old 01-19-2009, 09:24 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
You could get away with the factory LS6 parts and make some nice power...but the FAST 92mm intake combo will definitely help out for the kind of racing you're talking about! We stock the FAST combos with TB starting at $1099 and also offer the ported intakes as well. The stock injectors will likely be plenty for this power level, but if you plan to upgrade the heads or cubes down the road, I'd recommend going ahead and getting into some FAST or Racetronix injectors now so you have room to grow a bit!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-19-2009, 09:35 AM
Jason 98 TA's Avatar
Definately give us a call, we have dyno sheets testing the components your discussing. We can give you engine dyno data to help you choose your combo!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
