Can a stock LS1 be built to handle more boost?
Old 01-18-2009, 08:56 PM
Blevinator's Avatar
Smile Can a stock LS1 be built to handle more boost?
I am buying a D1SC kit very soon, and am wondering what I have to do to build the stock block to handle more boost. I understand my stock on LS1 can handle 550-600 rwhp? Can I build it up to handle more hp? What can I do, and how much max rwhp wil it be able to handle?
Thank you!
Old 01-18-2009, 09:01 PM
Captain_Stabbin's Avatar
do you mean as in the block holding more power? what kinda power are you looking to make?
Old 01-18-2009, 09:26 PM
Blevinator's Avatar
650-800 rwhp?
Old 01-18-2009, 09:31 PM
NemesisC5's Avatar
Originally Posted by Blevinator
650-800 rwhp?
Stock short block & rotating assembly???
Old 01-18-2009, 10:07 PM
Blevinator's Avatar
Bone stock everything.
Old 01-18-2009, 10:17 PM
WYATT318MOPAR's Avatar
Sounds like a steep order to fill on a stock short block. Pistons would never take that much boost without busting the ring glands. Least parts I would think you could get away with are pistons and rods. Crank could probably stand that may want to have balanced and polished up while you had things apart if you wanted
Old 01-18-2009, 10:53 PM
Customizing Director
MadIceV8's Avatar
You'll need forged rods and pistons. The block and crank are fine stock.
Old 01-20-2009, 12:03 PM
BLNLS1/RX7's Avatar
I ran my stock LS1 motor with a ProCharger (D1SC) for 3 years without any problems but I had a GREAT tune by Brent at Exotic Performance Plus.
Old 01-20-2009, 12:37 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
This info is useless unless you were making above 550rwhp.. Mine did great too for quite a while with a good tune, but it was at 489rwhp. And I still ended up breaking a piston.
To answer the OP's question: you kinda contradict your own question. How do you "build up" a completely "bone stock everything" engine? That makes no sense at all. You will be on the edge of the fence at 500-550rwhp as to what the stock pistons can handle. Nothing can change that. But as has already been mentioned, the stock block and crank should be good to 800 rwhp easily. Best you can do to a stock short block is to put some 317 truck heads on to lower the compression a bit. That will help out, but the stock pistons are still crap..
Old 01-20-2009, 02:31 PM
BLNLS1/RX7's Avatar
Originally Posted by chevychad
this info is useless unless you were making above 550rwhp.. Mine did great too for quite a while with a good tune, but it was at 489rwhp. And i still ended up breaking a piston.
To answer the op's question: You kinda contradict your own question. How do you "build up" a completely "bone stock everything" engine? That makes no sense at all. You will be on the edge of the fence at 500-550rwhp as to what the stock pistons can handle. Nothing can change that. But as has already been mentioned, the stock block and crank should be good to 800 rwhp easily. Best you can do to a stock short block is to put some 317 truck heads on to lower the compression a bit. That will help out, but the stock pistons are still crap..
568rwhp
Old 01-21-2009, 05:01 AM
EPP
EPP's Avatar
Thumbs up
Thank you!
We took a 2004 346 C5 and used the stock crankshaft, added Callies Compstar rods and Diamond pistons, GT2-3 camshaft, Patriot LQ9 stage 2 heads, stock LS6 intake and throttle body, Borla shorty emissions headers with stock cats, ProCharger D-1SC at 16 psi, and got 740 rwhp.
The above Corvette was run hard on a 2.1 mile road course for two years, no durability problems. This car was also driven on a vacation from Chicago to the East Coast and back, and got 28 mpg. Here is a link to this car. http://www.exoticperformanceplus.com...Car.php?car=54
Here is what we charged for this engine build.
http://www.exoticperformanceplus.com...php?service=85 Bob
Old 01-21-2009, 09:30 PM
elias_799's Avatar
just get a forget 370 lq9. they go for around 3500 bucks. call up speed inc i am sure they have one.
Old 01-22-2009, 11:44 AM
longrange4u's Avatar
Hmmm... I am like everyone else, dont completely understand the question. Are you asking if there is anything you can do to your stock block without rebuilding it? Not really... you can put some LQ9 truck heads on it dropping your compression some, making your stock engine a little more capable to the boost. But I think the breaking point is still the same... its usually your #7 piston due to lack of fuel, breaks the ringland. (#7 is the back right piston as you look at the front of the car)
I was always curious if you swapped intakes to the edelbrock if that would fix that problem and give you more life in the engine.
My stock block saw 607RWHP... didnt last long there, saw blowby and broke my #7 on the 3rd-4th run down the strip at that boost level.
Old 01-22-2009, 01:10 PM
elias_799's Avatar
^^^ do the wiand intakes or the fast intakes solve that problem ?
Old 01-22-2009, 01:15 PM
No I dont think so... they are still the same basic design... all your air must first enter from the front... and pass across all our other pistons... leaving #7 for last!
The edelbrock intake the air comes center top and more evenly spreads... dont know if this has been tested on a stock block though.
Old 01-22-2009, 08:16 PM
elias_799's Avatar
i am thinking of getting a vic j now, cause i don't wanna blow up my short block yet. how much is for the intake and the elbow and who sells it?
Old 01-22-2009, 08:32 PM
ChevyChad's Avatar
Guys! Do a little research.. The intake direction does not solve the lean#7 issue. People have turned the intake completely around backwards to where the air enters towards the rear of the engine and #7 STILL has the same problem. The general consensus is that the lean#7 is primarily due to the blocked off cooling passages through the top of the heads where they are blocked off on the newer LS1 engines with LS6 intakes. So in short, a vic jr intake will do nothing for that particular issue.
Bottom line is that no matter how equal the airflow and fuel distribution, the stock crap pistons can only handle so much power! That is generally in the 500rwhp range. Mine broke a ringland at 489rwhp, and it was the #5 piston that let go, not #7. There is no *magic* way to make the stock internals handle a lot of HP. They were never designed for it, and they sure aren't built for it. If you want to make more than 500rwhp SAFELY then do yourself a favor and get a forged bottom end. Then you can worry about everything else thats gonna line up to break next including driveshaft, 10 bolt, etc. etc. etc.
Old 10-13-2009, 12:44 PM
Blevinator's Avatar
Who makes the PT88 rear mounted turbo longerange4u?
Also to clarify the original question, I meant stock block. Forged bottom end is what I am going with.
Old 10-13-2009, 12:55 PM
Josh@KY-Turbo's Avatar
There are a few Stock short block Turbo cars being built right now in hopes of chasing down the Stock Short Block record. 9.50 @ 141 or so is the record I think.
Old 10-13-2009, 01:14 PM
NemeSS's Avatar
iirc its h/c spray car with a th400.
Quick Reply: Can a stock LS1 be built to handle more boost?
