??? P1SC to D1SC ???
Old 01-19-2009, 01:38 PM
nichols92's Avatar
Default ??? P1SC to D1SC ???
So I sent my P1 off my vette back to Procharger on an exchange for a D1SC. I just got the "new" one but they sent my old blower back . They said they just upgraded the internals...
Old 01-19-2009, 02:18 PM
11Second Club
Gauge's Avatar
I'm sure the only difference is internal. If you look at Procharger's website you'll see that the specs are exactly the same in every respect except CFM, max power, and max boost. In fact, I'm curious what about them is different if the step-up ratio and inducer and exducer sizes are the same.
Old 01-19-2009, 02:39 PM
Aster's Avatar
Not sure about the rest, but the impeller itself is different between the two, and that is what makes the largest difference in my understanding.
Old 01-19-2009, 02:46 PM
stangbangin69's Avatar
did they upgrade the tag to "D1SC"? and did they put a new serial number on it? how much did they charge if i may ask? you can pm me if ya want. thank ya.
Old 01-19-2009, 02:50 PM
95zpro's Avatar
Yeah they make internal changes to the unit which upgrades it to the D1sc level; I think it's all about how much the units flow in cfm. I'm curious too, did they give you a different tag/serial number for the unit?
Old 01-19-2009, 03:39 PM
nichols92's Avatar
I dont have it in front of me so I dont know for sure if they changed the tag or not but I would assume they did. As far as the cost goes I will have to check the invoice as I ordered an F1R at the same time so I dont know for sure what the charge was. I want to say it was like $1000
Old 01-19-2009, 07:58 PM
EPP
EPP's Avatar
Yes, ProCharger does not exchange the P-1SC for a D-1SC, but rebuilds it into a D-1SC. Bob
Old 01-20-2009, 09:22 AM
Dumb Ass Vette Moderator
ls1290's Avatar
The P1 and D1 have the exact same outer casing. It is all in the internals Did they at least switch out the badge?
Old 01-20-2009, 04:11 PM
11Second Club
Gauge's Avatar
What internals are changed if the inducer and exduce diameters are the same and the step-up ratio doesn't change?
Old 01-20-2009, 08:09 PM
BlackNiteWS6's Avatar
impeller
Old 01-21-2009, 06:45 AM
Originally Posted by BlackNiteWS6
impeller
so, they charge that much to just change the impeller?
Old 01-21-2009, 12:18 PM
cws T/A's Avatar
https://ls1tech.com/forums/forced-in...cs-inside.html
Old 01-21-2009, 08:23 PM
nichols92's Avatar
Thanks, that F1 is crazy
Old 01-29-2009, 05:54 PM
nichols92's Avatar
It took a while for me to look at it but it looks like a brand new blower. They polished it up and they did put a new tag on it. should be a nice upgrade
Old 01-30-2009, 04:01 AM
EPP
EPP's Avatar
Thumbs up
Thanks for posting, ProCharger does a lot more than just replace the impeller. Bob
Old 01-30-2009, 03:11 PM
cool. any chance you found ur receipt on the cost to have it upgraded to a D1?
Old 01-30-2009, 11:40 PM
BOOSTED1995's Avatar
I called procharger last week.$1300 to upgrade to a D without a rebuild.Seems kinda steep.
Old 02-01-2009, 06:33 AM
EPP
EPP's Avatar
That is exactly why I try to get my customer's to go with the D-1SC kit to begin with. When you initially buy a ProCharger kit, the D-1SC upgrade is less than $300.00. Bob
Quick Reply: ??? P1SC to D1SC ???
