to stroke or not to stroke
Old 10-04-2003, 11:48 PM
redZ's Avatar
Default to stroke or not to stroke
How much money would I expect to put down on a stroker motor, the long block. I got 5000 right now just wondering if I have got anywhere near enough. Where would be the best place to get one with a warranty.
Old 10-04-2003, 11:50 PM
Classic's Avatar
Default Re: to stroke or not to stroke
In one word NO. I am building up a new motor myself, and even a stock cube, or 370 iron block, is more than that. The heads alone are going to run half that price.
It gets very very expensive, and I'm even doing it myself piece by piece. You could try that route to save some cash, but you run without a warranty.
Old 10-05-2003, 12:10 AM
redZ's Avatar
Yeah thats what I figured, just had extra money and was going to start looking into stroking my motor. Ill be able to do all myself so thats no problem. Also I got one more question has anyone put in Lunatis rotating assembly kit comes w/ crank, f/t pistons, etc..
Old 10-05-2003, 06:00 AM
11 Bravo's Avatar
Look at the price of the JPR all bore 382. Not a stroker per se, but make at least as much, probably more, power than a 382 stroker.
Old 10-05-2003, 06:38 AM
11 Bravo's Avatar
Never mind, you said longblock. No way will 5K get you close to that.
Old 10-05-2003, 08:14 AM
Restricted User
2001 Pewter WS6's Avatar
I did the Lunati kit. I am very happy with it. You just need to get your cylinders torque honed .005 for the new pistons and rings. If you built it yourself, you would be close to $5000 including heads. More around the $5500 range with a cam, oil pump and timing chain added to the mix. Talk with Kevin at Ramchargers. He has GREAT pricing on the Lunati stroker kits.
Old 10-05-2003, 01:36 PM
dis3as3d's Avatar
what cam did you go with for the lunati kit?
Old 10-05-2003, 08:22 PM
Restricted User
236/240 .602/.608 112 LSA. I chose the wrong valve springs (Comp 987's) and had a bad case of floating the valves. It is in the process of being remedied as we speak.
Old 10-08-2003, 09:46 PM
Excal's Avatar
ok JPR has a 382 shortblock for $4250..
damn cubic inches are EXPENSIVE.
so what would the rest of the longblock run me?
(assuming i would choose mild h/c among LTs, ls6 intake lid mayeb cutouts ect ect)
