LS6 intake question ?
Old 01-20-2009, 04:27 PM
miji_am's Avatar
Default LS6 intake question ?
i have an GM LS6 Intake Manifold un ported and im thinking of getting a Nick Williams 90mm TB , the question is will i gain anything from it,
u can see my mods on my sig.
thanx
Old 01-20-2009, 05:08 PM
Unertl42's Avatar
the opening into your intake manifold will need to be ported to let more air in. I believe the LS6 is 76mm, so it needs to be ported to make more power
Old 01-20-2009, 06:10 PM
01ssreda4's Avatar
its a 75 mm opening i believe...will a 90mm even bolt up to it??
Old 01-20-2009, 06:23 PM
MattysTA's Avatar
no it wont and thats why im modding mine...
Old 01-20-2009, 10:28 PM
SweetS10V8's Avatar
What companies do this? Lingenfelter and TPIS?
Is it plastic welded?
Old 01-21-2009, 03:40 AM
MattysTA's Avatar
only tpis does it, lingenfelter is a distributer i believe. dont know if they plastic weld theres but thats what im doing
Old 01-21-2009, 09:19 AM
teke184's Avatar
OP
since the stock opening is 75mm....there is very little to be gained from putting a 90mm throttle body on.
unless the intake manifold is modified like TPIS does.
basically you're fine with a ported stock throttle body.
Old 01-23-2009, 06:58 AM
miji_am's Avatar
Thanx every body for the help , so my next question is how much should i port my stock TB . in mm
thanx
Old 01-23-2009, 07:05 AM
teke184's Avatar
you don't actually increase the bore diameter of the TB. you remove the lip directly in front of the blade, and you smooth out the transition as air approaches the blade.
while some places machine the bore bigger, you then have to put a bigger blade in.
