Best 16 injector intake.
Old 01-20-2009, 10:37 PM
6 Second Club Moderator
LASTLS1's Avatar
Default Best 16 injector intake.
Who has them and how much. Who in the boost world has used one? Pics? Looking for a quality and for one asap.
Btw, it has to work on a LS7 style head.
Old 01-20-2009, 10:47 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
i have a vic jr with 16injectors. cheap
Old 01-20-2009, 10:50 PM
93formto98T/A's Avatar
I don't believe you have many if any choices besides the GMPP and victor jr single plane intakes. Also, they have to be custom modded at a shop for 8 extra injector bungs and 2 extra rails. There are quite a few on the site running these in big power setups. I couldn't run a single plane with 16inj due to hood clearance issues so I will have to make do with a standard ls intake and 8 large injectors.
Old 01-20-2009, 11:02 PM
LASTLS1's Avatar
Pics and price please. Oh, one little problem it has to work on a LS7 style head.
Old 01-21-2009, 08:47 AM
Coal Mining Director
onfire's Avatar
Hogan has made a few custom 16 injector intakes for LPE. He can build one for a LS7.
http://www.lingenfelter.com/images/C6ZO6EL03.jpg
Old 01-21-2009, 08:49 AM
Classic's Avatar
If you want to see one, Speed Inc. should have one for my TT build. LS7 GMPP manifold, 16 injectors, staged injection w/ BS3.
If you don't go with a carb manifold, sheetmetal is your other option. I talked to Beck about doing one for my setup as well and of course he can make it an LS7 style as well.
Old 01-21-2009, 11:57 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Thats badass!!
Old 01-21-2009, 12:31 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Damn, mine is for a cathedral port head
Old 01-21-2009, 12:37 PM
Rickys S/C Z28's Avatar
that is ******* bad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-21-2009, 01:16 PM
stevieturbo's Avatar
I just used a carb intake on mine, LS1/6/2 style heads.
Old 01-21-2009, 02:04 PM
1320's Avatar
you got a pm........
Old 01-21-2009, 02:09 PM
ONEBADWS6's Avatar
Andy get one of Cary's intakes and have him put in bungs for 16 injectors. That and a 4in fabed elbo would rock.
Old 01-21-2009, 03:29 PM
sevanseriesta's Avatar
juiced, had one I am not sure if he still does or not
Old 01-21-2009, 03:38 PM
Silver_TransAm's Avatar
Where did you get that elbow? Custom?
Old 01-21-2009, 03:44 PM
everyone's got you worried about yours, huh?
Old 01-21-2009, 04:06 PM
ehh...All I can do is try.
Old 01-21-2009, 04:17 PM
It's Intakeelbows.com stock item for an F-body. So custom yes...but not uniquely so.
Old 01-21-2009, 04:44 PM
pwrtrip75's Avatar
not to hijack his thread but can you run a stock PCM and use 2 sets of injectors? Just splice the extra terminal into the existing one and then multiply your injector table by 2?
Old 01-21-2009, 04:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,221 Likes on 778 Posts
LS1Tech 10 Year
Classis you are running a composite or cast carb intake? Forgive my dullness.
Old 01-21-2009, 04:48 PM
10sec_rx7 was looking into this, but not sure if he ever did get it working.
In theory, as long as the injector drivers can handle the current, then no reason why you could run a pair of say 60lb's to achieve 120lb of flow.
You'd need to divide your fuelling by 2, as double will get injected.
I dont use a stock ecu.
Quick Reply: Best 16 injector intake.
