Anyone using the felpro blue pan gasket
Instructions say not to use any sealant on the gasket,does it seal well in the corners without it. Don't want to have to take it back apart cus it leaks. THANKS JOHN B
i have them on my car and the back gasket leaks a little bit so i lifted the block an put silacone all the way around it and now no leaks! so i'd put sealent. with these LT1's they like to leak anywhere and everwhere so put Lock tight on EVERY nut an bolt and use lots of silacone! lol i just used RV clear silacone...
I used the felpro gasket and black silicone on the corners but I have a leak between the timing cover and oil pan. Looks like I will either pull the engine or slap some more sealer on the lip of the pan !
^That's exactly why I'm doing it. I don't see any point in removing the old gasket and having all those chunks fall into the oil pan, not having a clean surface, and letting all kinds of debris stay there.
