car will not turn over with key
Old 01-21-2009, 08:55 PM
showstoMpinSS's Avatar
Default car will not turn over with key
i just got done putting my car together and everything turns on like radio, fuel pump, gauges, etc. but when i go to turn the car over nothing happens, i have everything plugged up except i dont have the radiator, ac condensor or e fans in but i dont think that would be a prob. Can anyone help me out?
Old 01-21-2009, 09:55 PM
tj1986c's Avatar
Does the car make any sounds when you try to crank it?
Old 01-21-2009, 10:10 PM
custm72chevy's Avatar
check any wires going to your starter!
Old 01-22-2009, 05:17 AM
poconojoe's Avatar
Sounds like the BCM isn't letting the relay engage for the anti-theft, jump the relay
Old 01-22-2009, 05:28 PM
where is the relay? ive turned it over from the starter
Old 01-22-2009, 05:34 PM
poconojoe's Avatar
What's the vehicle?
Old 01-22-2009, 05:38 PM
2000 camaro ss
Old 01-22-2009, 08:00 PM
poconojoe's Avatar
In the engine wiring harness junction block 2, which is located on the left side of the engine compartment. There are 2 junction blocks there, the rearward one is #2 The relay should have 4 wires a dark green, a yellow with a black stripe, A purple wire, and a red wire. you want to jump the red to the purple and try to start it.
Old 01-22-2009, 08:15 PM
k, thnx im gonna try that now
Old 01-23-2009, 09:26 PM
Bill Bowling's Avatar
Did you ever get it to turn over?
Bill
Old 01-24-2009, 02:17 PM
well i can start it up if jump the starter but it starts up and turns right off
Old 01-24-2009, 04:55 PM
98Camarod's Avatar
Throwing any codes, flashing SES?
Old 01-24-2009, 07:59 PM
poconojoe's Avatar
You have a vats issue
Old 01-25-2009, 10:14 PM
ok well just got done putting everything in fans, radiator, maf, etc. i can jump it from relay and everything runs fine but still cannot start with the key, but i can turn it off with key, ha go figure, well if anyone knows whats going on it would help me alot, thnx guys
Old 01-26-2009, 05:12 AM
poconojoe's Avatar
Email me I'll send you the wiring diagrams
Old 01-27-2009, 04:28 PM
well maybe its bc i have an LT 1 steering coulmn, would that be it?
e mail is rss197mxer@aol.com
