Question about stock valve springs in particular 02 year
Old 01-24-2009, 09:18 AM
Intercooler2's Avatar
Default Question about stock valve springs in particular 02 year
Talked with SLP the other day and did some searching here. Is it correct the 98's had the weakest springs? My search here said that 02's had the same springs as LS-6 motors or at least an equal spring. Anyone have info?
Old 01-24-2009, 06:10 PM
Thought someone here would know the springs on the 02 241 heads
Old 01-24-2009, 06:28 PM
2xLS1's Avatar
All 97-04 LS1s came with the same spring. 01 LS6s had a different spring and 02+ LS6s had a different spring. LS2s came with the same spring as the 02+ LS6.
Old 01-24-2009, 07:02 PM
Post #19 in here: https://ls1tech.com/forums/generatio...questions.html
"If you have an '02 then you don't need to upgrade the springs! They are the same Z06 springs. ALL '02 LS1 & LS6 engines came with the same springs, clutch, oil pump, intake, hydraulics. I would buy a set of Harlan Sharp 1.8 for $330 shipped and forget about SLP rockers"
SLP also told me 02's had better springs. Never had the covers off mine to look. This is where I am confused
Old 01-24-2009, 09:33 PM
2xLS1's Avatar
Yea, there are people that believe some came with 243 heads too. Doesn't mean they did. I've done spring swaps on every year LS1 they made. Have a dealer look up the part number for the springs. Or just believe whatever you want.
Old 02-03-2009, 08:55 PM
jetlag's Avatar
My springs are not yellow.
Old 02-04-2009, 11:55 AM
S10xGN's Avatar
Just swapped out the springs on my '03 LS-1 (base 350HP) and they were plain colored, no stripes or other paint marks...
Russ
Old 02-05-2009, 07:25 AM
zman1969's Avatar
Default springs
i would tend to believe this more than the other statement
my .02c
