Question about stock valve springs in particular 02 year
Talked with SLP the other day and did some searching here. Is it correct the 98's had the weakest springs? My search here said that 02's had the same springs as LS-6 motors or at least an equal spring. Anyone have info?
Post #19 in here: https://ls1tech.com/forums/generatio...questions.html
"If you have an '02 then you don't need to upgrade the springs! They are the same Z06 springs. ALL '02 LS1 & LS6 engines came with the same springs, clutch, oil pump, intake, hydraulics. I would buy a set of Harlan Sharp 1.8 for $330 shipped and forget about SLP rockers"
SLP also told me 02's had better springs. Never had the covers off mine to look. This is where I am confused
My springs are not yellow.
