5.3 head and cam combo
i have a 98 transam ls1 with a a4 iwant to go with a head and cam swap im lookin at texas speed 5.3 2.5 heads with eather the 233/239 cam or a more agressive ms3 cam, also i need a stall also so im thinking tci 3500 lockup and 3.73 gears? am i heading in the right direction? do i need to know about anything else like piston clearance with those heads? any info is a big help thanks-matt
Add an electric cutout, I wouldn't go with a stall that is under 3600. Personally I would go with a 4000-4400 stall.
I would only use three converter companies. I would go with Yank, Circle-D or Vigilante. Not in that order specifically.....
LS6 didn't show me any great gains, I'd look into a FAST 90/90 or 92/92 since you are doing H/C
i just finished a ms3 stage 2.5 5.3 combo and love it. im an m6 but with the ms3 and an auto i would prob go with at least a 3800-4000 stall. If you buy them as a combo from tsp they will sink the valves a little to run the ms3. with the other cam they wouldnt have to i dont believe. call tsp up though they are very knowledgeable and very friendly and helpfull.
yea but are they 6 speeds? if they are they will naturally produce more hp. honestly the tci is not a good converter for the ls cars. i have seen problems with them not locking out. but go with whatever your budget looks like. i run a yank and have installed vigilante and they both are awesome converters. i wouldnt get over a 3600 though. a 4000 is too much stall for what you have at the moment. i run a yank 3600 in my car and it works perfect.
LS1Tech Premium Sponsor
We've done tons of the PRC Stage 2.5 5.3l heads & cam combos. I recently finished a Tsunami & PRC Stage 2.5 5.3l heads car that made right around 450rwhp!
http://www.texas-speed.com/shop/item...id=84&catid=20
http://www.texas-speed.com/shop/item...d=203&catid=47
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
