Fuel regulator Which one works well?
Old 01-26-2009, 08:17 PM
RascalsRodsCustoms's Avatar
Default Fuel regulator Which one works well?
I'm using After market Fuel Rails (Areomotive), on a LS1,(in 69 camaro w DSE Tank) has anyone used the Areomotive fuel regualtor ? also is it best to buy one that has a Fuel return, and plumb the return from the rail into that, then to the tank ?
Old 01-27-2009, 02:55 PM
Nasty N8's Avatar
Give me a call I can help you setup you swap system.
Nate
Old 01-27-2009, 02:59 PM
C5Fire's Avatar
Rascalsrods,
Call Aeromotive. Talk to Brett in the tech department. He's awesome to work with and will get you lined out with everything needed to finish your system. I don't like mis-matching components from different company's so I would just stick with Aeromotive, besides they are the best!
Old 01-29-2009, 09:48 PM
C5Fire, thanks for the advice, I called Brett, really helpful !Took time to explain everyhting needed & why, return vs. non, nitrous hook-ups, examined my fuel pump out put for the applicatione, etc, I'm sold on Aeromotive !
Old 02-02-2009, 12:31 PM
C5Fire's Avatar
You're welcome! Glad you got everything lined out.
Old 02-02-2009, 01:22 PM
Disturbed Bird's Avatar
aeromotive
Old 02-02-2009, 02:52 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Seems like when I did my research, most of the people on here were very much against Aeromotive regulators, and is what steered me toward the Fuelab setup I currently run.
Old 02-02-2009, 09:01 PM
davidws6's Avatar
Default Reg
I'm using a Magnafuel and it's been good so far...
