Biggest cam for 241 heads & 243 heads?
Old 01-27-2009, 12:59 PM
alamantia's Avatar
Default Biggest cam for 241 heads & 243 heads?
I have a 2002 Z28 6-Speed with long tubes on a bone stock engine.
I did some research and found out that the biggest cam I would want to run on my 241 heads would be a 224/224-112LSA (which im sure is a big point of contraversy)
If I upograde to 243 heads, at that point what would be the biggest cam I would want to run?
Old 01-27-2009, 01:44 PM
blue98Z's Avatar
Hmmmmmm.....................Guess I need to pull my 228/230 out then since I have 853 heads
You can put a larger cam in than 224. Your heads may not support it to its full potential, but it will still run hard. Read around some more on here and you'll see much bigger cams with those heads. If you plan to upgrade the heads later then plan on a cam that you will want to use with them and put it in or wait til you get the heads and do it all at once. Just my .02.
Old 01-27-2009, 01:46 PM
conan's Avatar
I had a 224/568/112lsa cam on my bolton stock headed ls1 for my first setup and it was a nice cam but after a week I wished I had gone bigger. A 224 cam would be the smallest cam I would recomend for some one wanting some power lol. Here's some reading materal for you. Stock ls1 with 241 heads... https://ls1tech.com/forums/generatio...mparision.html
Old 01-27-2009, 04:06 PM
alamantia's Avatar
Does anyone have a reccomedaton for a cam to use that would best match a 243 head?
Old 01-27-2009, 04:07 PM
ssick1's Avatar
maybe ls6 cam?
The following users liked this post:
HioSSilver (12-22-2020)
Old 01-27-2009, 04:11 PM
Bird's Avatar
I've been running an F-14 (234/600/112) with 806 castings for a while - no problems. Pulls strong, but can tell it want's more flow. Porting up a set of 241's that should really wake it up soon.
Bird
Old 01-27-2009, 04:14 PM
streetassasin's Avatar
I am looking for some 243 heads and am going to run a MS3 237/242 .603/.609
Old 01-27-2009, 04:27 PM
alamantia's Avatar
Cool, good advice, thanks
Old 01-27-2009, 10:05 PM
382ssz28's Avatar
241's here. .595"-.598", 232*-234*, 112. .030" removed when CNCed. .041" Cometics. Clayed .128"-E, .098"-I. 7200RPM. You should have room. What bottom end do you have?
Old 01-27-2009, 10:19 PM
BillyBob750's Avatar
236/238 601 605 113LSA, Stock 243's, LS2 GTO
Drives damn near like stock.
Old 01-27-2009, 10:21 PM
Restricted User
willyfastz's Avatar
The real guestion here is what are your goals for the car? Is it a DD or just a strip car. Do you want the car to be fun to drive? Theres way more to getting the right cam than asking for the biggest you can run.
Old 01-27-2009, 10:29 PM
2FNQUIK's Avatar
sounds like Billy Bob is running the vrx5 or similar..how do you like your cam as far as daily driving manners
Old 01-28-2009, 01:10 AM
SOMbitch's Avatar
And you must be flycut too
OH I just caught it. The diamonds keep your pistons and valves from getting acquainted
Old 01-28-2009, 01:14 AM
shudog's Avatar
Talk to the guys at Texas Speed & Performance or another respected sponsor. Tell them what your goals are. "Biggest cam" may not be what you're actually looking for based on your needs/uses for the car.
Old 01-28-2009, 02:02 AM
Cape T/A's Avatar
exactaly, but you he can go with a much bigger cam than the 224.
Old 01-28-2009, 03:21 AM
chieftransam's Avatar
On 58cc 243's I'm running a 230/234 .612/.598 112lsa using stock gaskets.
Old 01-28-2009, 03:40 AM
El_Diablo's Avatar
Dunno what's goin on in this thread but I'll throw this out there. MS4 and TRex are just about the biggest baddest cams you can run on stock 241s. I went with a TRex .608/.612 on 110+2 lsa. I trapped 123mph with a 3450ish raceweight. (ls6 intake/78mm throttle body) Nothin fancy. Mine made good torque too. It's a blast to drive around.
fucter (01-19-2021)
Old 01-28-2009, 09:48 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You can definately run some large camshafts with stock 241 heads, but that might not be what's best for your application. Whats your goals for the car? What future mods do you plan?
The MS3 & MS4 both fit fine, but there's several smaller camshafts we sell that make power earlier in the rpm... I personally like the Torquer V3 a lot, but the 228R is also a great camshaft for someone looking to keep the camshaft on the smaller side...
http://www.texas-speed.com/shop/item...d=167&catid=44
http://www.texas-speed.com/shop/item...d=669&catid=44
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-28-2009, 08:07 PM
JPH
JPH's Avatar
I Agree with Jason. A 228/228 or 228/232 on a 112 would be awesome!
Old 01-28-2009, 08:55 PM
Minshall's Avatar
Im running the LG Motorsports G5X4 cam in my 02 Z28 with stock heads and head gaskets.
Quick Reply: Biggest cam for 241 heads & 243 heads?
