LQ4 Compression, piston selection
Can anyone help me figure out what pistons I need to run with this setup to make or get as close as possible to 11:1 compression. I am thinking flattops with -2cc valve reliefs.
LQ4 block bored .30 over
PRC 5.3 stage 2.5 heads 220cc
Chamber size: 62.5cc
Stock GM gasket .52
4.030 bore
3.622 stroke
Cam is 230/232 .613/.595 on 111+1LSA
Thank you!
Stock GM gasket .52
4.030 bore
3.622 stroke
Thank you!
That is pretty much what I'm doing, except that I'll be using an MS3 cam. Static compression will be exactly at 11:1. Hope to make at least 400 rwhp through a stalled auto... I do foresee a lot of tire shredding in the future...
