just bought z28 with hp tuners. will not read from car????
Old 02-01-2009, 06:10 PM
wes302's Avatar
Default just bought z28 with hp tuners. will not read from car????
just bought z28 with hp tuners program.
VCM Editor: 1.4.6
ERR:
VCM Flash: 1.4.5
ERR:
VCM Scanner: 1.4.7
ERR:
VCM Suite Opt: 0 0 0 0
VCM Suite ID: 00000A330F
GM Firebird/Camaro (V8) 1998
program will work but will not read from car. what will i need to do to make this work? on disk it has id# and ver 1.4.5
previous owner cant find any of the keys?
Old 02-01-2009, 07:12 PM
Moderator
jimmyblue's Avatar
That's a pretty old version of software.
Check that the cig lighter fuse is not blown, the OBDII port
gets its power from that feed. If it "can't find" then this is a
likely bet. There should not be a hangup with scanning the
vehicle, whether you are properly licensed or not.
Older (serial) HPTuners hardware didn't use license keys,
the software (and any updates) were put out with the user's
licensure embedded in it. Speaking of updates, you ought to
get yourself "in the system" as the present owner of the
cable, and get the last update for serial hardware (?) as it
is past the end of active support, or will be soon.
Old 02-01-2009, 08:05 PM
wes302's Avatar
just plugged in a scanner and it worked fine. i used a rs232 from usb to tuner i had same problem as cable previous owner had( the radio shack usb to serial was not vista comp) . i will go buy a usb to serial adapter that is made for vista
Old 02-01-2009, 09:45 PM
LS1TECH Sponsor
foff667's Avatar
That version is roughly 5 years old & might not have even supported the older 98 LS1 pcm's. Update your software to the newest public version for starters.
Old 02-02-2009, 06:14 AM
wes302's Avatar
where do you update at?
Old 02-02-2009, 07:10 AM
LS1TECH Sponsor
foff667's Avatar
www.hptuners.com
Old 02-02-2009, 07:31 PM
wes302's Avatar
these guys have great support for there product. thanks
Old 02-04-2009, 07:19 AM
LS1TECH Sponsor
foff667's Avatar
Thank you!
