Who makes this C5 kit??
Old 02-01-2009, 07:06 PM
INVISIBLEZ's Avatar
Default Who makes this C5 kit??
Interested in possibly picking this kit up from my buddy. Any pros and cons to it??
Old 02-01-2009, 07:59 PM
405HP_Z06's Avatar
Is that on old Halltech kit?
Old 02-01-2009, 08:00 PM
CraZee ZO6's Avatar
looks like it..
but their are ebay kits that are replicas like it..
Old 02-02-2009, 02:05 AM
chuntington101's Avatar
looks more like a PTS/PTK kits, or one of the ebay kits.....
dont knock the Ebay stuff too much. i hear the piping is all satinless (PTS used mild steel) and thing line up pretty well!!
Chris.
Old 02-02-2009, 09:25 AM
viper9403's Avatar
Chris.
I agree, could be either.
Old 02-02-2009, 10:38 AM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
Looks like the old PTK kit, but there is a now a copy on E-Bay that requires extra parts/work to make it work.
Old 02-02-2009, 12:54 PM
wilson34's Avatar
If that is the car it is coming off of then it is the ebay kit. But if that is not the car it could be a few kits.
Old 02-02-2009, 01:18 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Looks alot like the PTK kit on V-Series' Techs car....
https://ls1tech.com/forums/corvette-...ock+786+bottom
https://ls1tech.com/forums/dynamomet...ock+786+bottom
If so, pros, it will support more power than most Vettes will harness....cons, time, money, a little fabbing to make it all fit, oh, and time, and money....lol.
You'll want to look into a way to get rid of some heat under the hood as well, and get used to being sideways under throttle.
Old 02-02-2009, 01:20 PM
NemeSS's Avatar
looks like the one bad chad adapated to his fox mustang swap
Old 02-02-2009, 04:19 PM
wilson34's Avatar
Well thats Vadian's car and he bought the ebay kit so if that is the car it is coming off of its the ebay one, if not then idk
Old 02-02-2009, 06:13 PM
Shawn @ VA Speed's Avatar
That is def an ebay kit,you can tell by the way the pipes are going to the wastegates,they are cut and welded at a wierd angle.
Old 02-02-2009, 08:08 PM
Tainted's Avatar
looks close to the ptk kit but man oh man get ready for a melt down!
Old 02-02-2009, 10:59 PM
sloganish's Avatar
it looks at home in that engine bay
Old 02-02-2009, 11:11 PM
ls1_chevelle's Avatar
Those appear to be ebay knock off Tial gates aswell. No engraving by the flange. My guess is ebay.
Old 02-03-2009, 02:12 AM
you can get these kits to work and work very well even with VERY hard driving! AVB on here has a PTK kit on his 408 vette that he used for road course work. thats 20min HARD driving per session...
also nick yoskin on here has made over 1000bhp with the same kit.
yes you cant just bolt the kit on and drive around at full throttle all day and not expect heat probelms. but with a little bit of thought you can get rid of them.
Chris.
Old 02-03-2009, 04:57 AM
Vadian's Avatar
Thats my car.
It is the ebay kit.
100% stainless except for the cold piping which is aluminum. The only alignment problems I had was bolting one of the manifolds to the head; I had to open up some of the mounting holes very slightly.
If I had to do it again, I wouldn't. I would of made my own kit since I've chopped this one up so much already.
Otherwise, for what I paid, it produced decent numbers.
Here's a dyno on the stock LS6 @ 7psi.
Here's a dyno with my current 440ci LS7/L92
Those were with the... and I quote... "crappy"... Ebay/chinese T61 turbos.
Since then, I have upgraded to Turbonetics TC76s only because I wanted more. I was getting too much backpressure on the turbine side on the 61s to make the power I want. I've also upgraded downpipes (completely 3"), wastegate piping and wastegates (50mm). Hopefully I'll have numbers within a month.
Old 02-03-2009, 01:29 PM
NemeSS's Avatar
how much chopping did u actually have to do to make align correctly?
Old 02-03-2009, 08:11 PM
Vadian's Avatar
I didn't chop it up due to any alignment problems. Those pictures were before I did any piping modifications. The only fitment issues I had was one exhaust manifold mating to the head. Some bolt holes needed to be opened up slightly.
I chopped it up because I wanted a completely 3" exhaust; the kit has a 3" v-band right at the turbo but immediately necks down to 2.75". I cut that out and re-did it in 3". Also, I cut the downpipes in multiple pieces and installed v-bands to make it easier to install/uninstall.
Also, I re-did the piping to the wastegates. As someone said earlier, the angles were wack and I was having some boost creep. So I did them in 2" with a lot smoother bends while giving the new 50mm wastegates more exhaust bias.
Next I'll be re-doing some of the charge piping. They are 2" from compressor to intercooler and I'll be going to 2.5" to match my compressor housing outlets.
Old 02-04-2009, 02:25 AM
Vadian, have you got any pics of the motor now?? be nice to see the mods you have done next to the kit as it came..
also what turbos are you using on the 440ci ls7??
Cheers
Chris.
PS. that torque curve looks really good!
Old 02-04-2009, 06:39 PM
Vadian's Avatar
I don't have any pics at the moment.
The turbos that were on the car on that last dyno were the T61s that came with the kit.
I now have Turbonetics TC76s.
Quick Reply: Who makes this C5 kit??
