Injector?
Old 02-02-2009, 03:53 PM
deuce4935's Avatar
Question Injector?
Anyone know what series injectors will work on 96' LT1? I'm looking at these injectors and they say they're EVI-1. Anyone know if they're compatible with our engines? Also they're made by Siemens.
Old 02-02-2009, 04:01 PM
ss.slp.ls1's Avatar
First, what is your current set up? Did you use an injector calculator to determine that you actually need upgraded injectors?
If it has a EV1 connection, likely it will work on a LT1, but you will need to tune your car for any injector size/flow that is larger/greater than stock.
Old 02-02-2009, 04:05 PM
deuce4935's Avatar
As of now I have 28lb/hr injectors in a 355c.i. lt1 with a hotcam. Now I'm going solid roller, 0.600" lift, and no I have not used an inj calculator, and yes I pan on having the engine retuned for the new setup.
Old 02-02-2009, 04:10 PM
ss.slp.ls1's Avatar
Try the calc and see if you are over the duty cycle for those injectors.
Old 02-02-2009, 04:12 PM
baylove's Avatar
what determines if you need bigger injectors or not ??
Old 02-02-2009, 04:14 PM
ss.slp.ls1's Avatar
Fuel demand, aka power level.
Old 02-02-2009, 04:26 PM
deuce4935's Avatar
Where can I find the calculator?
Old 02-02-2009, 04:37 PM
ss.slp.ls1's Avatar
http://www.rceng.com/technical.aspx
Google is your friend.
