Western Members CA, AZ, NV, UT, CO, NM, HI
What is CETA
Old 02-02-2009, 07:49 PM
ur jlus's Avatar
Default What is CETA
i see it in referance to T/A's.
Old 02-02-2009, 07:53 PM
MrElectric03's Avatar
Collectors Edition Trans Am...they had the area around the exhaust painted black...CETA mod
They came out in 02 and are all Yellow with a special stripe package.
Old 02-02-2009, 08:01 PM
BigDaddyBry's Avatar
Colorful Electric Trans Am.
Chevy's hybrid of the new Volt and Camaro to appeal to Firebird enthusiasts.
Old 02-02-2009, 08:17 PM
Damn I thought I had it...
Old 02-02-2009, 08:47 PM
White Fire'99's Avatar
its the T/A in this add.
Old 02-02-2009, 09:43 PM
donman's Avatar
Or in this avatar...
Old 02-02-2009, 09:46 PM
PwrHngryLT1's Avatar
so thats what that mods called "ceta mod" didn't know that prior, i think of it as the berger mod but for firebirds....
Old 02-02-2009, 11:28 PM
camarojunky74's Avatar
yes but not way overdone such as the "berger" panel which has gotten so played out, noobs refer to their stock rear panel as the berger panel.
Old 02-03-2009, 12:03 AM
noriceinside's Avatar
yep. CETA mod
Old 02-03-2009, 12:04 AM
Originally Posted by noriceinside
yep. CETA mod
on my to do list...
Old 02-03-2009, 12:10 AM
do it. its easy and cheap. go to home depot and get some 400 grit and then some 800 grit. then grab some primer and black spray paint. you can get either flat, semi-gloss, or gloss. i went with satin, which is like a semi-gloss. mask off the whole back of the car and start wet sanding the section to be painted with the 400 grit. spray down a coat of primer. let it dry. wet sand with 800 grit. spray a coat of black. let it dry. done. took me about 4 hours total and less than $20 in parts. i suck with paint and mine looks professional and is smooth.
Old 02-03-2009, 12:20 AM
Thats the thing is im affraid i will screw it up or it will flake or something.
Old 02-03-2009, 12:33 AM
its all in the prep. if you clean it well and sand it well and apply even thin coats you will be fine.
Old 02-03-2009, 12:42 AM
Hmm, I may just have to give it a shot sometime soon. What type of paint did you use? Anything special?Plastic or something like that.
Old 02-03-2009, 01:57 AM
lowerthanyou00's Avatar
now thats funny and badass at the sametime
Old 02-03-2009, 02:26 AM
carbonfiberbird's Avatar
I was thinking about doing it on my trans am. I like subtulties so I think it would look cool. My TA is black btw.
Old 02-03-2009, 09:36 AM
ss.slp.ls1's Avatar
Paint it Chevy black, lol, jk...You'd have to go with flat black, and even then, I don't know how much it would stand out.
Old 02-03-2009, 09:40 AM
Boulevardvette's Avatar
one of these
Old 02-03-2009, 09:42 AM
LS1Adam84's Avatar
Unless he did it reverse of the CETA and paint it yellow ohhhhh..... LOL
Old 02-03-2009, 08:40 PM
ur jlus's Avatar
Thanks! BTW I did the flat black to the rear panel of my 69 Firebird back in the mid 80's. I guess I was ahead of my time. I only did it because the car was candy apple red and I was warned people would not see my tail lights.
