Cam questions
Cam questions
just looking for a recommendation really. Getting ready to order some KooksLT's and ORY and hopefully get ahold of a used LS6. I'm kinda confused about what cam to go with. goal is 400-425. I also plan on 3.90's as well. I know I will have to spin her past 6500, but don't want to go o 7K if i dont' have to.
I have searched and that left me more confused than aything.
Sorry I shoukd have specified, heads are not in the wqation right now. Maybe the end of the year with a 92/92 if I have the time.
HTX-What would it take to do it with a 224? I personally want sometihng in the 232/232 range, but may consider the 224.
Hadn't thought about it truthfully. I've seen some good numbers from a reverse split cam, but it was bigger than a 228
no, you do not need heads to hit 400 with a 224. You just need all the supporting mods done properly. Go to the dyno section and check out the cam only results. There are several people that have accomplished the task.
and a 232/232 can put you anywhere in the 390 to 430 rwhp range. Do a search for the "El torro" cam. Pred Z speced it. it is a 230/230. Chris1313 put down 420rwhp in an automatic with that cam and no deads, did not even need a FAST intake.
