engine rebuilders check this out
This is my first rebuild and I have noticed two things different with my 02 block and my 98 block.
On the 98 block there are two plugs, one on the front of the engine and one on the rear. The front on is to the right of the oil pump and looks like a freeze plug. The second one is on the rear and to the left of the crankshaft. It looks like a freeze plug but installed upside down. Here is a two pics of what I am talking about they are rather large to see what I am talking about
The 02 block doesn't have them, are they important or a revision between the two years. I would hate to get this thing all bottoned up and start it if those two plugs need to be there. To toast this new engine would suck
Thanks,
J
Thanks,
J
Super Moderator
Re: engine rebuilders check this out
Don't think the first one is a big deal, but the second one is the oil galley plug. Never seen one without it, but it could have been deleted in the 2002 year. If the hole is there and you leave that plug out, you will have no oil pressure.
they are both required, otherwise you'll have no oilpressure.
The first blocks one end of the galley that runs along the bottom skirt of the block, they second block the back and diverts the oil into and back out of the filter.
They are not in the new block cause the might have been removed if the block was tanked.
Senior Member
HOLY **** Thanks Harlan. I guess I will be ordering these two things today. I called the machine shop and he swears he didn't take them out.
Does anyone have some GM numbers for these off hand.
Harlan
Carl, that's exactly what I was afraid of, no oil pressure. I've never read up on this because I thought the blocks were good to go from GM sources, I am glad I noticed it.
J
Harlan
J
12558340 for the plug in the back. DO NOT reuse the old one The blocks dont come with them installed
Senior Member
I imagine there could be. You know how when you first get something (like a woman ) and its all new then you "use" it once and then its just not as tight as before .... same thing The book says not to reuse the old one and at $4.00, its a safe bet to replace it
No offence to the ladies here.. just a very crude way to explain it... its all I could think of
Senior Member
Thanks for the PN Carl Now I need the front plug number and I am all set. Lets see if the guys at the dealership can find what I need.
Thanks all,
J
Thanks all,
J
Have part, Ill have the part number
Thanks again Carl you are a major help. I like your way of explaining stuff. Too bad the local dealerships don't stock any LS1 parts, I always have to special order stuff from them. So I called Valvegod(shaun) and he had them on hand and will have them here by friday. This board is awesome.
on a side note:
I was checking out my old heads and I had a broken valvespring, but all the pistons are fine on the old LS1, It is the very bottom coil, I never heard any racket-car is too loud from both ends s/c up front Loudmouth in the rear and I have only one good ear, lol. I ran a best of 11.36@120 the other night on it too. My previous best was 11.5@117!
The spring was a comp cams spring but not a 918, I will dig up the reciept to find out what I bought back in the day for my Lil B1 cam. I wonder how long it was broke? I have pics if anyone wants to see them.
Thanks for all the help guys,
J
on a side note:
J
Senior Member
No problem I usually get my parts from gmpartsdirect.com because some of the parts are more than 1/2 of what dealers sell them for. Its just shipping is high unless you buy multiple thing
