VATS Rant
VATS Rant
Just needed to rant a little. The VATS on my 02 took a dump. The car would not start the other day when my brother was trying to move it. Figured I would try to bypass it. It worked for a couple of days. My brother tried to move it again to get his car out and he had trouble starting it. Looks like I am going to have to cough up $500 to get it fixed. Hopefully I can at least start it to get it to the shop. The sad thing is I rarely drive the car and this is the first thing that has needed to be fixed on the car since owning it. I will be taking it in next week to get it fixed.
End rant...
End rant...
End rant...
End rant...
Where does $500 come from?
A new ignition-lock+keys from the dealer is less than $200.
Getting a tune and having VATS disabled is probably less than $500 as well, and you'd get a tune as well..
Yes, the dealer will rape you for over $400 if you take it to them...don't! Same thing happened with my buddies car and I bypassed it and it has worked flawlessly ever since. Are you sure you used the right nominal resistence value when you spliced in the reistor(s)? You said it worked for a couple of days, now it doesn't...does the security light flash now when you try to start it?
Are you sure you did it correctly?
You'll need to test your key to know what ohm resistor to use http://shbox.com/1/4th_gen_tech2.html#pass_key
I have HP Tuners and 2002 Camaro License. I can turn it off for you if you want.
End rant...
End rant...
