Cam?????
Sorry cars is a 2002 camaro SS a4 dyno said 347rwhp would like to get to 400 or 450 anywhere in beween is good. Daily driver but only drive 1.2 miles day... Also car has 31kmiles on it is.... Would like to beat the mach1 that this guy drives to my work lol
Get a custom grind cam. They do not cost much more and you get a cam that works for YOUR application.........not someone else's application.
Asking for someones opinion on which camshaft to use is like pissing in the wind............asking on the internet is like asking 5 guys to **** in the wind with you........Get a custom grind.......at least the cam grinder will know which way the wind is blowing!
deciding not to go with a stall convertor really limits your choices to smaller cams. Probably a good idea since you probably also don't want to spin your stock trans into 6500+ territory (it doesn't like that for long). Smaller cams won't "thump" a lot either since that is related to overlap. Overlap comes from a relationship between lobe durations and seperation angles.. not often seen in small cams. imo a stall would be one of my very first mods on an A4. Even on a stock cam.
