26" or 28" tall tire......
Ok so I'm finally pulling the trigger on doing 15s out back. My question is should I go with a 26'' tall tire 275/50/15 or 28'' 275/60/15 Mickey Thompson drag radial?
So far I have been running 275/40/17 MT drag radials...
Thanks,
Matt
Thanks,
Matt
What he said ^^^^
Unless you are running out of gear then i would stay with a 26" tall tire. I am running a 28" tall tire on the street and at the track but it is only because on the spray I run out of gear in 4th.
And those 17s are about 1/4 shorter than the 50 series. With 28s you can stage stall and flash convertor as high as you can wich may be around 3800-4000. Well for one how do you launch? what RPM do you leave at with your current tires?
With the 50s you could launch harder cuz of the sidewall(obviously) but you wou run out of gear with 4:10s. I think there is a calculator on here to better help you. I think its in a sticky at the top. Also check out the drag racing section to see what other Auto guys with your gears and stall some what close too yours run.
just add spray for the 28s. I found that on motor my car was best on 26" tires but while on the bottle the 26s got their *** kicked, So I bumped it up to a 28" and was rippin 1.601s fairly constistantly with a T/A only suspension. BTW your car rolls out hard for bolt ons
