ignition help
ignition help
i got this car 2 days ago and i was working fine..then when i was driving if started poping really loud and backfireing a lil bit then it tuernd off and dident want to turen back on so i got a new msd coil and it had a hard time tuerning on but it finaly fired up and it was working fine then after i was driveing it for like 30m it stared poping one more time and tuernd off but after 1 or 2m cranking the car it tuernd back on so whants going on with the car is it the coil, distributor, cap and rotor, ignition control module what can it be.... right now the car will fire up and it drives fine but it take like 1m to finaly tuern on...the car also has a msd 6a box, cam, and some other stuff it is 6 speed 1995 z28 lt1 need help bad thanks
My old 94 Z28 had very similar problems once. It turned out to be the O2 sensors. If you unplug them and the car runs right then its most likely the O2 sensors. I was really broke back then and I actually just unplugged mine and drove it like that for 2 years before I sold it. If I ever hooked the O2's back up it would start sputtering again.
i havent checked the codes but the car runs smooth no sputtering or eney thing just out of no wher it stared poping and backfireing and then it turens off then theres no spark cuz i can smell the gas when im cranking it and cranking it then finaly it will get spark i guess and turn on
http://shbox.com/1/xraycable.jpg
