O2's Tell me the difference
Re: O2's Tell me the difference
Front O2s watch and measure oxygen coming out of the motor. They also help in the misfire tests.
Rear O2s watch what happens to the gases after they pass the catalytic converters.
The O2s on an LT1 are different (err, at least OBDI LT1's, not sure about OBDII).
You can use simms on the rears, but not the fronts. The PCM is really just watching the signal from the rears to make sure that they are transitioning across .45 volts (which is 14.7:1 AFR). The simms just sit there and toggle up and down around this voltage.
If you're running open loop, front O2s are ignored.
If you're at full throttle, front O2s are ignored.
If you're at partial throttle, front O2s measure oxygen content, and the fuel trims are updated correspondingly (rich / lean trends). PCM adjusts injector pulsewidth based on this info.
Fronts do all the work. Rears are... Optional.
Andrew
Andrew
the thing with the rears is for the obd2 testing. i had my rear o2's deleted from the computer and it passed inspection, in the computer at least. like he said they should read about .450 and thats a legal for passing emission testing. but pretty much the rears are there for cars who need state inspections and they read off the o2's now instead of the sniffer, on the 96 and up cars. anything older than 96 has one o2 before the cat to just monitor the engine and how rich/lean it is running. there is not one after the cat becasue it is obd1 and requires a tail pipe sniffer test....here in NC at least
Andrew
Restricted User
Andrew
In New Zealand even the cats are optional (although that may change soon).
Paul
The post cat LT1 02's are the same part # as the pre and post cat LS1 02's. A friend bought the wrong ones for his LT1 (rear instead of front) and they were the same # as mine.
