best dd cam please??
what is the biggest cam can work well without TC
i wanna best result without torque conventer
i have 04 A4 GTO with 241 heads and full boltons
thanks aloot
thanks aloot
The words "biggest cam" and "stock TC" do not go together at all. Even with the stock cam a 3k stall converter will wake the car up big time. Putting a larger cam on the stock TC will make it a dog off the line unless you are going small (224-228ish). If you don't have the budget for both, I would recomend getting the converter first and the cam later.
Re'
Re'
the MS4 is probably the best cam I can think of to run on the stock converter. its down low power range is perfectly suited to factory TC.
seriously though, why even cam it if you dont want a stall,? let me guess you just want the sound??? if thats the case slap in the HOT CAM and be on your way.
Formerly darynC-10/23/10
maybe some people just want a little more umph in thier car without having to get into other areas, seriously i have had a tr224 all the way up to the t-rex. on my 99 camaro the 224 was pushing my stock tourque converter if you dont want to get into them areas then the 224 is the most you want.... either that or a ls6 cam
subscribed
a 220/220
220/224 would be good on a 114 lsa
ls6 cam will maintain near stock driveability w/ a few extra ponies
unfortunatley this is the road less traveled so help will be close to nill
a 220/220
TR224/230 or 224/228 or TR224 , ..................
these cams i think it will working good with stock converter
i wanna the best to gain nice power
thanks aloot guys
i use TR224-112 on my babe (which it in the sign) i run 11.89 with stock converter
thanks aloot guys
[QUOTE=69_YENKO;11014840]the MS4 is probably the best cam I can think of to run on the stock converter. its down low power range is perfectly suited to factory TC.
THAT'S SOME FUNNY ****!!!
