What is the biggest FMIC that will fit 98 f body?
I am thinking of doing twin 62mm on a 408ci. What is the biggest FMIC you can fit on a 98 camaro and where to get one.
LS1TECH Sponsor
Not saying it wouldn't be a bitch to do and weigh a ton, but in theory it can be done. In reality it is not practical. Again, at 1800 HP A2W is the way to go.
Making the blanket statement that a2w is far better at those power levels is just wrong. If the vehicle were purely a drag car I wouldn't even contest your statement. For a street car a properly sized a2a core is more than capable of doing the job just fine. On the flip side I haven't seen an adequate a2a I/C on this board since I joined. The a2a core I was referring to also comes in at just over 40lbs, about the same weight as the water and water reservoir in a typical a2w set-up.
I'll try to get pics tomorrow.
Coal Mining Director
You really need to know how much pressure drop a core will have at the rated flow to REALLY know how much HP it will support efficiently. Plus the thermal efficiency.
You could take a 12 x 12 x 3 inch core and say it supports 1700 hp....and it will...with a pressure drop north of 6psi and an outlet temp north of 200F. These IC companies need to provide more info....IC's are like Fuel pumps...you need to know the flow curve to really know what you have.
turbo'd stang,
Is that the 24x12x4.5 core? If it is and you are making that kind of power I'd suggest getting a bigger core.
Onfire mentioned some key points to having a sufficient intercooler. There is no definitive answer to an acceptable pressure drop across the core but if you are seeing more than 5psi difference your core is too small. Also if intake temps are sky rocketing(more that 15-20 degrees in a 1/4 mile pass) you core is either of poor quality or it's too small and you need something bigger.
