Strange Noise With Patriot Head and Cam
Just finished my head cam package on my 02 Z and now there is a strange whining noise while your coming up through the rpms. I went with 225/229 580/590 114 LSA howards cam and 2.02"/1.57"/64cc LS6 style stage II heads. The guy that tuned it said it sounded like a valve train noise that he hears a lot from Patriot Heads. Anyone with similar problem have a clue?
Did you change timing chain and sprockets? "Whining" noise should not be head related.
Try using an automotive stethoscope to isolate where the noise in coming from. Here are a few sources. Your Sears or auto parts might have one in stock.
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
http://www.amazon.com/Mechanics-Stet.../dp/B000RB5WQY
Did not change the timing change or sprockets, they only have 30k miles on them, the sound can only be heard in the car when reving the engine. If your outside the car under the hood you cant hear anything. The guy I had tune it said it was valve train noise that he hears a lot with patriot heads.
The valvetrain noise that will have with our heads sometimes is a result of the Patriot Gold valve springs. The greater pressures will sometimes result in a slight valvetrain noise that is a "clicking" noise but not a whining noise.
My car is cam only and I have had what I call more of a whirring noise since the cam and springs (918). It's like you describe. It's not very loud but there and the shop said it was just the springs working. It's been that way for around 2 years and the car runs great so I have not worried about it.
