Who here is running a Procharger with a MAF?
Old 02-09-2009, 02:32 PM
T/AWS6969's Avatar
Talking Who here is running a Procharger with a MAF?
The reason i ask is because my SES light is on some days and sometimes off(?). When SES is on it seems like the throttle resonse is slower for some reason. Should i just get a SD tune or just take it back to the tuner after i get the TB ported? Will getting a SD tune give me a better throttle response or is my dilemma just common with having forced induction with an unported TB? Originally Bob at EPP suggested i stay with the MAF, but maybe its just because at my high elevation may have something to do with it (5200 ft). Any input greatly appreciated!!!
Old 02-09-2009, 02:41 PM
badass99ss's Avatar
I had a problem with my MAF as well but my tuner was able to solve the issue. It sounds like a different problem than yours. Here is the link to my thread. Maybe you will find something that is useful.
https://ls1tech.com/forums/forced-in...zy-f-help.html
As of now im only at 8 psi, but when I swap over to the F1a and 15psi I will go SD.
Troy
Old 02-09-2009, 02:57 PM
T/AWS6969's Avatar
hmmmm..... my maf never had a screen (?)
Old 02-09-2009, 02:59 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Running a MAF since 05 with no issues. Everything else...
Old 02-09-2009, 03:08 PM
T/AWS6969's Avatar
maybe i should rotate and reclean (did it a couple months ago) my maf.
Old 02-09-2009, 03:13 PM
Mr.Big's Avatar
mine isn't the same setup but full MAF car/setup here... the haltech 103.5mm MAF with the 2008+LS3 maf card is the new thing for my car, not sure why this wouldn't adapt to your setup, several LS1,2,3,7 guys are going this route, may be worth a look...
Old 02-09-2009, 03:24 PM
T/AWS6969's Avatar
god knows it would be a great excuse to get a bigger MAF! LOL! If it fixes the problem of course
Old 02-09-2009, 04:48 PM
'Trust''s Avatar
I would just go speed density, the stock MAF can't keep up (i.e., say you want the effect of it commanding 11:1, you may have to actually command it at 7:1 to get the right ratio). SD dumdumdum.
Old 02-09-2009, 06:29 PM
T/AWS6969's Avatar
anyone else?? i am just trying to figure out what to do
Old 02-09-2009, 06:58 PM
Boosted 99 TA's Avatar
im not procharged but i went SD after i turbo'd my car and it has good throttle response.
Old 02-10-2009, 07:58 AM
BLNLS1/RX7's Avatar
Go ahead and get a speed denisty tune and be done with it.You will be a lot happier with the end result.
Old 02-10-2009, 08:24 AM
Dumb Ass Vette Moderator
ls1290's Avatar
LS1Tech 20 Year Member
Old 02-10-2009, 12:13 PM
BLNLS1/RX7's Avatar
Originally Posted by ls1290
DENSITY (sorry)
Old 02-11-2009, 09:59 AM
ls 2 goat's Avatar
I'm running a 100mm MAF with an LS7 sensor and am maxed out. I'm going to go SD as soon as I throw the F-1 on and up the boost.
Old 02-11-2009, 10:23 AM
dschmittie1's Avatar
I think really you need to see what the code is that you are setting. If it is MAF related problem I would go SD I am running SD with my car.
Old 02-11-2009, 11:24 AM
618HAWK's Avatar
Pm sent on a great local tuner who can help you out. As stated I would start with finding out what the current cods are. To see which direcetion to go, be it in the tune, MAF or supporting function.
Old 02-11-2009, 11:47 AM
vette_c6's Avatar
sounds intresting
what should i do with my 2006 vette
cant tune it SD ... the HP tuner cant change my OS to 3 bar ,,, any suggestions ?
Old 02-11-2009, 12:44 PM
ls1290's Avatar
Originally Posted by vette_c6
sounds intresting
cant tune it sd ... The hp tuner cant change my os to 3 bar ,,, any suggestions ?
BS3 or DFI
Old 02-11-2009, 03:43 PM
TS6
TS6's Avatar
You don't even know what code you're throwing? How the hell can you even guess if you don't even know what the problem is?
Keep the maf, plenty of guys making big power with it if you have a competent tuner.
Quick Reply: Who here is running a Procharger with a MAF?
