new centerline wheels
So has anyone check them out? I am looking at getting a set and was wondering what anybody elses thoughts on them were. Looking at the new Rev, Qualifier, or Split Spoke.
I have the Qualifiers on my car. Heres a couple shots. The fronts fit no grinding the rears will need a lot I would just run drag brakes in the rear.
i placed my order a few weeks ago on a set... ill post pics when i get them, i cant get the installed pics for a bit due to the rear not totally fabricated/completed yet. cant tell you guys which ones yet...
The site says 5 ++ back spaces available so if you call them they will make what you want. Warning though these will not work on the rears with out heavy grinding on the 15's the fronts fit no grinding.
15x8 Telstars required no grinding on the rear of my car (LT1). When I spoke to Centerline a couple weeks ago, they told me that if the 15x8 clears, then the 15x10 should as well. Sounds like the Qualifiers may have less clearance than the Telstars.
BADHAWK - I assume it wasn't the width of the rim that was giving you issues?
No width was no issue they actually hit in a weird place where the bolt goes threw the caliper so basically it is the 15in height issue.
