Stereo & Electronics - led flashers
View Full Version : led flashers
Nick_Rapitis
02-15-2009, 12:27 AM
is this what i need to make em work?
click here (http://cgi.ebay.com/ebaymotors/TRIDON-EL-12-12-VOLT-ELECTRONIC-FLASHER-2-TERMINALS_W0QQcmdZViewItemQQitemZ280305182805QQptZ MotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories)
TireSm0ke
02-15-2009, 02:46 AM
yeah that will work
Nick_Rapitis
02-15-2009, 08:58 AM
where do i put it in? lol
TireSm0ke
02-15-2009, 08:16 PM
Its pretty easy to get to, the turn signal flasher is under the driver side footwell panel (the middle panel, not the one directly over the pedals) and its just 2 phillips screws up top and 2 9/32 screws down bellow. The flasher module is sitting right above the OBD port, just pop it out and it will go right back in. You will also need to replace the hazard light flasher, its the same EL12 module and its located on the lower left drivers side kick panel, kind of right behind the hood release. I dont remember exactly how to get to it but it shouldnt be too tough... good luck.
Nick_Rapitis
02-15-2009, 08:22 PM
so i need two of the things i ordered?
TireSm0ke
02-16-2009, 05:11 AM
yes, if u want the hazards to work properly. im pretty sure you can just get them at your local auto parts store.
Nick_Rapitis
02-16-2009, 09:31 AM
ok thanks man
Danny2tek
02-16-2009, 09:18 PM
I just replaced the one for the turn signals, and my hazards still work fine :confused:
TireSm0ke
02-16-2009, 09:50 PM
Are you running LED flashers? The stock thermal flasher might work but it will either blink really slow or fast, or wont blink at all.
