MALF 16: Lo-Res Fail
Old 02-15-2009, 03:37 PM
pyro719's Avatar
Default MALF 16: Lo-Res Fail
Just logged my car for the first time today with datamaster. And a DTC MALF 16: Lo-Res Fail popped up? The car runs fine, I think? Is my opti shot? Will this lower horsepoer and performance?
Old 02-15-2009, 03:56 PM
RamAir95TA's Avatar
Chances are it's a stored code if your car runs fine. Pull the PCM/BAT fuse for a minute or two, then rescan.
DTC 16 means loss of low-resolution pulse from the opti. Usually means your opti is on it's way out.
Old 02-15-2009, 05:19 PM
pyro719's Avatar
I cleared the codes with free scan and it came back should I disconnect the battery anyway?
Old 02-15-2009, 05:40 PM
RamAir95TA's Avatar
Yes...disconnect it.
Old 02-15-2009, 05:54 PM
pyro719's Avatar
will do Ill have to try again next weekend. Thanks For the help
