12 disc changer
Old 02-15-2009, 10:47 PM
Iceman can's Avatar
Default 12 disc changer
I know some of us have Ipods now and dont need the 12 disc cd changer. Just wondering if anyone else removed it. Took it out and left the wire there.
Old 02-16-2009, 12:21 AM
nemss1's Avatar
i removed my 12 disc and wiring. not hard, plastic panels on drivers side just have to come out to remove the cd changer wiring
Old 02-16-2009, 10:41 AM
Ungrounded Moderator
WhiteBird00's Avatar
You can remove the changer and leave the wiring. Monsoon equipped cars that didn't have a changer still came from the factory with the wiring harness in place. There is no need to remove the harness unless you are obsessed with removing extra wiring or feel that the extra 12 ounces of wire will slow you down.
Old 02-16-2009, 12:55 PM
nemss1's Avatar
^^^im obsessed
Old 02-16-2009, 01:22 PM
Iceman can's Avatar
haha...i see that. Don't know if it's worth the effort though.
Old 02-16-2009, 11:46 PM
nemss1's Avatar
its not really all that hard if u wanna remove the harness and wiring.fairly easy. just remove the drivers seat, left rear passenger bucket and the upper rear seat back. remove the kick panel, sail panel (pull clothes hanger and velcro behind) and remove the hatch speaker panel
peel the carpet back a lil and remove the cd changer wiring frm the bundle of wires running to the front of the car
Old 02-17-2009, 08:46 AM
And just what do you gain by doing all that?
Old 02-17-2009, 09:37 AM
shoemike's Avatar
Would the CD changer`s power and ground wires be good for an aftermarket amp?
Old 02-17-2009, 12:44 PM
A small one... The circuit runs off the 25-amp RADIO ACCY fuse which also protects the Monsoon amp and the power antenna. A small amp of no more than a couple hundred watts would probably be okay but anything bigger should have better wiring.
Old 02-17-2009, 12:51 PM
nemss1's Avatar
security and peace of mind knowing i dont NEED it and it is removed
Old 02-22-2009, 09:24 PM
Snipezzz's Avatar
(((yes thes should be)))
Old 02-22-2009, 11:58 PM
nemss1's Avatar
no sir
need thicker guage wire
Quick Reply: 12 disc changer
