Is this good?
Old 02-16-2009, 02:38 PM
john_stout's Avatar
Default Is this good?
Went to the track yesterday, street tires 32 psi, lid, no muffler, 02 z28 a4 camaro.
rt.. .541
60' 2.063
330 5.601
1/8 8.507
mph 85.37
1000 10.964
1/4 13.047
mph 107.68
I know I could have hit high 12s, for some reason my car bounced of redline 2 times I think going from 1st to 2nd, I have no clue whats going on with it.
Old 02-16-2009, 03:50 PM
S8ER95Z's Avatar
for just a couple of mods I would say that is awesome!! nice times.
What are the specs on those tires?
Old 02-16-2009, 05:44 PM
john_stout's Avatar
They are fuzion zri, almost bald.
Old 02-16-2009, 06:06 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Not bad, I'd be happy with it.
On the rev limiter, are you running the trans in drive or OD? I was getting the same thing, then got a suggestion to put the shifter in OD instead of D. Hasn't done it since.
Derek
Old 02-17-2009, 01:55 AM
john_stout's Avatar
Thanks, im running it in od.
Old 02-17-2009, 08:15 AM
S8ER95Z's Avatar
I used to hit the limiter with my custom tune on my stalled/built LT1 setup... I changed gears and forgot to update them in the tune. I would guess that even a minor change in the tire diameter could cause problems too... (those tires still stock spec? maybe a bit taller or shorter?)
Old 02-17-2009, 10:11 AM
john_stout's Avatar
Old 02-17-2009, 10:57 AM
S8ER95Z's Avatar
Hmm..unless your converter is slipping or you have some slippage (bad clutches in the trans) I can't think of any reason it would slap the limiter.
Old 02-17-2009, 02:12 PM
john_stout's Avatar
It seems to only do it at the track, I tried to see if it would do it on the street and it didnt.
Quick Reply: Is this good?
