60lb injectors @ 110%
Old 02-16-2009, 07:33 PM
cjg454ss's Avatar
Default 60lb injectors @ 110%
on a 370, pt88, it seems odd to me that at 11psi they at almost maxed out. no way im making 750rwhp at 11 psi. base pressure 60psi, boost referenced. -8 feed, twin walbros, aeromotive rails.
Labels 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
Flow 69.26006 69.69410 70.12814 70.56218 70.99621 71.43025 71.86429 72.23632 72.67036 73.10440 73.47643 73.91047 74.28250 74.71654 75.08857 75.52261 75.89464
Old 02-16-2009, 07:40 PM
MotleyDrew's Avatar
my 403ci with YSi/12.5lbs was maxed the 60lbers out at 108% and made 770rwhp. I also run boost ref with twin 255lph pumps and meth. My base fuel pressure is at 45psi.
http://www.youtube.com/watch?v=lkDNJlDNa9k
I needed the Ford 80#'s for my 16+lbs now
Old 02-16-2009, 07:42 PM
cjg454ss's Avatar
dang does that mean my setup it working good together. did you get the 80s yet? if so how do you like them, whats the duty cycle at 16psi?
Old 02-16-2009, 07:46 PM
MotleyDrew's Avatar
I do have the 80#ers bt they are not installed yet. I have actually run the 60's up to around 15+ lbs on the street but never logged the run to see how much they were at.
Your base fp is higher than mine which should give you a bit more injector but you are still pushing them right now at your poiwer level. I would think your setup is probaly OK you just need some bigger injectors
Not every car is the same as you know and neither is each injector. Mine ar ethe Motron;s.
Take care
Old 02-17-2009, 04:51 AM
vette_c6's Avatar
get Lucas Fuel injector 79#
i bought them From Fraser in Speedinc
or the other thing if you wanna keep your Fuel injector ,, get another external Fuel pump
.. but i think your setup is okkay
if i were in your shose i would get bigger injector and thats it,,,,
Old 02-17-2009, 07:25 AM
cjg454ss's Avatar
are the 80s from ford a new injector or a modified 60?
Old 02-17-2009, 09:02 AM
qqwqeqwrqwqtq's Avatar
The 80's are a new ford injector, not modified.
I've had success geting a bit more out of the 60's at 5bar base pressure
Old 02-17-2009, 09:07 AM
mterveen's Avatar
Default Ifr
is that how you have your IFR table set up? with boost referenced return style fuel system i believe the flows should all be the same for each kpa label.
Old 02-17-2009, 09:22 AM
Old Geezer's Avatar
Default Yep..
Being boost referenced, the boost seen at the nozzle end of the injector puts the "delta P"[net psi] at what the base setting is...
IE:
Base. line off = 60psi.
Gauge reading w/ 1:1 ratio boost reference, @ 15# boost = 75psi.
Delta P = 75-15, right back at base of 60.[Thus, you are getting fuel volume at the 60psi pressure.]
Old 02-17-2009, 11:45 AM
405HP_Z06's Avatar
Agree, you need the 69.26006 value in all cells of the IFR table. You also need to modify the injector offset table the same way.
Old 02-17-2009, 12:42 PM
cjg454ss's Avatar
ok thanks for the info, with that effect my duty cycle %? how do i modify the offset table?
