is this lifter tap?
12 Second Truck Club
is this lifter tap?
got two vids. dont mind the loud 60's in there.
http://videos.streetfire.net/video/t...4-8dafc79eb310
took some pics of the valve cover. it looks like a few of the lifters have been shooting some nasty stuff up through the push rods. don't mind the grass i washed it off.
my car makes the same exact sound but not even close to being that loud, but mine goes away when the car is warm.. so im wondering the same thing...
Yup, thats a lifter. Im in the exact same boat as you are right now. Im in the process of replacing them with the LS7 lifters.
Heres my link with my videos
https://ls1tech.com/forums/generatio...head-area.html
last two replies. https://ls1tech.com/forums/generatio...head-area.html did you ever find a part number for ls1 size 5 layer gaskets?
the only good thing here is i think i have a blown head gasket on that side any way. the block is wet and the reservoir is almost empty. now if i can just get my ls6 heads finished.
i was ready where some one was talking about weak valve springs can cause the lifters to go. would ls6 springs with 10psi be considered weak?
ok so i ordered new lifters, patriot gold springs, arp studs, and gm 3 layer gaskets. got the even bank lifters out. how can you tell if they are bad? they all look the same. i took some apart. one that i think is bad and one i think is good. the "bad" one had about half the amount of oil as the "good" one inside it. i can't squish any of them by just using my finger while they are completely together.
