Does anyone have a good right up for removing heads
Hey since my lt1 decided to blow a head gasket is there a good right up on how to remove the heads. Also is there a good wright up on port and polishing heads.
its pretty easy and straight forward. like said get a haynes manual. the bad thing about the manual is it will tell you to do alot of things to do that makes it "easy" but time consuming. i pulled my heads with studs, engine in the car in about 4 hours. just take your time and stay organized.
