Bolt on LT1 with TH 400???
hey guys just a question about my trans. Im looking into swapping my M6 to TH400 RMVB, trans brake and around a 3800 stall. My car currently just has bolt ons, suspension and lots of weight reduction...in the 3k race weight range. Now the question is if i swap to a TH400 how much would that help me out? btw i will be running a 4.10 gear with 2765/60/15 ET Street Radials.
thanks in advance
thanks in advance
haha yea! wish i could fit a tire that wide, much less afford one! lol
Um are you on the stock 10-bolt? I kinda decided against a transbrake for my setup. Mainly because that it is a big jolt once you let go of the button, and if you want to find the weak point in your car that will probably show it to ya!
damn it i was hoping i could get away with using the stock aluminum one i have....That's what i was thinking just run the 4k stall because the car will still see street duty during the summer.
I installed a th400 with 3800 converter and t-brake, that dropped my 60' from 2.20 on the 6-speed to 1.51 on the th400. Both were on the factory 10 bolt with 4.10 gears.
Also you will need another drive shaft for the install.
I have searched high and low on this forum and others and have not found any links to this conversion. I have found plenty on the LS* to TH400 so if you guys have any actual links that you can post up for me that would be a great help. I have tried in vain with every combination of phrases that I can think of and none have worked.
Thanks,
Joe
Thanks,
Joe
For the swap your gonna need to get a Trans, TQ Converter(Im pretty sure a standard GEN1 converter will bolt right up), Flexplate(I used a stock 4L60 for my swap), Trans Xmember(Used a bmr peice for my car), Drive shaft, shifter of your choice and a big trans cooler and a trans temp gauge is always a nice thing to have.
I run a th400. you ran reuse your t56 crossmember with some simple mods. I have a nice billet protorque converter that would work well with your setup, it went 4000 or so behind a mild 383. You'll need a new driveshaft, I had a local shop build a 3" chromoly for 350 bucks.
