Free Mods
Free Mods
Since I'm a relative n00b to all this LSx stuff...Can anyone tell me what the free mods are for these damn cars is? I can't get any of my so-called "buddies" to tell me. Thanks Guys!
well you can re rout the cooling lines to were they dont run through your throtle body, and you can also cut the pastic out of the air filtier tray if you take your air filter out you will be able to see what im talking about
Bump Stop Mod> If you manually open your throttle, you will wee the manufacturer has the casting where the throttle will hit and stop at WOT, notice the throttle plate is not completely open, its about 90% open, so you carefully grind the casting material so the throttle opens all the way, when done properly, you would look at the front of throttle body in the WOT position and see the plate is straight across, equal space top and bottom, like a minus sign hehe.
