$140 for replacement light, any other options?
Old 02-25-2009, 12:08 PM
01z
01z's Avatar
Default $140 for replacement light, any other options?
my lowbeam went out on the driver side and to my dismay there is no bulb to swap out. so i go to the stealership and they said its 140 for the "capsule".
this sucks, i just want to go to autozone and buy a 2 dollar bulb
is there any other option out there?
Old 02-25-2009, 12:47 PM
1 Bad Ass Formula's Avatar
You can buy the headlamps at Autozone for about $14 or $15 each. My advice is buy two of those and replace the pass side while you're at it so that they match. They should have the headlamp PN: look-up book there to ensure that you get the right ones.
Old 02-25-2009, 01:02 PM
Jersey Mike's Avatar
My highbeam was out & I thought it was the bulb. Turned out to be a wiring problem. Check to see if that's the case with yours too.
Old 02-25-2009, 10:34 PM
Blackened2k's Avatar
Search Eurolamps (Eurolights?) I have em and they rock. I can send link through PM if you want.
88 bucks. Gets you two bulbs of your choice and 2 new housings that let you change your bulbs anytime you want.
Here's a post I made on another forum to show off the difference.
http://triadfbody.com/forums/viewtopic.php?t=3535
Old 02-25-2009, 11:15 PM
IMgettingLS1's Avatar
they make a bulb, ive changed many of them you just have to epoxy it on. ive never had an problem done it with 4 fbodys
Old 02-27-2009, 12:07 AM
w3s1c0a5t's Avatar
Pretty good info their sir. Good post.
Old 02-27-2009, 02:26 AM
SOM02WS6's Avatar
Or just go to autozone and get the sealed beam for like 12 bucks!!! Its not that hard,,,
Old 02-27-2009, 03:21 AM
myk
myk's Avatar
Wait a minute. $140? Aren't these sealed beam units like in the early 4th Gen-Camaro's? They're pricey at 40 or so dollars but certainly not $140; what are they selling at that price?
Old 02-27-2009, 04:09 AM
Joshiedoom's Avatar
What the hell is going on here. 13 bucks Xtra vision low beam. I have the box right beside me.Much brighter than stock and damn cheap. Change them in like 3 minutes.)
Im with SOM02ws6
Quick Reply: $140 for replacement light, any other options?
