what i hear everytime i crank my car
Old 02-25-2009, 05:29 PM
futuref-body's Avatar
Default what i hear everytime i crank my car
i previously posted this in the external engine section but felt that it was proper to post here. note:this isnt just when i crank it, it is whenever the engine is running, hot cold no matter what. now im thinking that it may be a lifter(s). so if anyone else ever had this-please share!
http://www.youtube.com/watch?v=faTls...eature=channel
Old 02-25-2009, 05:37 PM
IGNANt's Avatar
sounds like a lifter or two, no matter what you still gotta pull it apart...
Old 02-25-2009, 05:53 PM
yeah-instead of spending money to get it checked out id rather use the money towards parts to fix it. so hopefully someone can tell me what it is. if noone knows-then it might go to the shop and spend some money to get it checked out.
Old 02-25-2009, 06:09 PM
lifeisgood's Avatar
bent pushrod?
Old 02-25-2009, 06:13 PM
that has ran through my mind too. maybe ill change rods AND lifters and see if that makes it stop
Old 02-25-2009, 06:37 PM
uLs1a's Avatar
Sounds just like my car, Im in the process of swapping out the lifters and pushrods
Old 02-25-2009, 06:44 PM
SladeX's Avatar
sounds like a collapsed lifter, I have the same issue with mine where in certain situations I have a lifter deflate a bit on me. It's enough to cause that slap sound.
try running a thicker oil, or just tossing in some oil thickener like stop leak and see if that affects the sound.
Old 02-25-2009, 06:50 PM
YES! im glad some people actually know what im talking about! i guess ill be buying some ls7 lifters and lunati pushrods-sound good? i would try some thicker oil but just knowing that something is wrong and me not hearing it would worry me all the more!
Old 02-25-2009, 06:54 PM
and if my lifters are messed up, is it possible that the corresponding lobes on the cam are F'd up too?
Old 02-25-2009, 08:08 PM
uLs1a's Avatar
Depends on how bad the lifter is and how hard you drove the car. I didnt drive mine for 2 weeks unil my 110 mile drive home becasue I did not want to risk anything.
I have a friend whos SS just started ticking, so in a few weeks Im probably gonna take the vavle covers off and check somethings out
Old 02-25-2009, 09:10 PM
max_ta's Avatar
cam lobe on my sons car caused something similar to that, it was a custom grind
Old 02-25-2009, 11:13 PM
i am praying my cam is ok! i can afford a cam but idk about getting it installed! i would try myself but too much of a risk for a first timer with no supervision on a dd.
