can i update my map sensor, 98 camaro
talked to some people about my fuel systems and they recommend that I upgrade to a 2 bar map sensor, is this possible on a 98 z28, btw i have a ls6 intake manifold
That's what she said...
You can go over 2-bar with the 2-bar setup, you'll just have to fudge the PE/etc up top, or the highest MAP cells, as it will stay in the highest cell row (210kpa or whatever). Not the best way to do it, but swapping the harness/pcm sucks. No way I'd swap the **** out to run 17-18psi.
You can do it without a 2bar OS. the map sensor will read half the voltage of the 1bar so you have to adjust all the tables that use MAP accordingly. The only thing weird about it is the table titles will read up to 105 kpa when in reality the 2 bar goes up to 200. you just have to adjust your thinking for that.
Dumb Ass Vette Moderator
