Water Temperature Sensor Bad?
I am trying to figure out my random and catalytic damage misfires are coming from.
It is super bad at cold, until it gets up to operating temp (180*). Then depending on weather outside(warmer the better), It either goes away completely, or still is there.
I replaced the o2 sensors. Brand New Flow Matched/Tested Injectors. 1 year old MSD 8.8MM Wires, 6 month old NGK TR6 plugs.
If the computer pickup for water temperature is incorrect, could it throw it off, and pull timing/add fuel/etc to cause this issue?
I have milled heads w/ a cam. 11.7:1 compression Ratio.
2 years no problems like this prior.
Recently Tuned in an attempt to fix problem. I have perfect A/F Ratio ~13.X.
Moderator
ECT sensor, or its connector, will whack the
operation big time if it's dead or simply flakey.
It could get better with just a pull & reseat of
the connector. Maybe inspect both for crust,
loose or pushed-back pins, etc.
no mine stopped....the 98 uses a 3 pole sensor....one wire comes from pcm,one wire is a return signal to the pcm,and the last wire operates the gauge.....do you have an ses light on.....
Yes, For Random Misfires.
And thanks for the input Jimmy and Slow.
If I wanted to check the 3-wire connector w/ a DMM, what would I need to do?
Changed plugs/IAT.
The code changed to P0353 and P0327(KS B.1 Low Input) Both KS are brand new and harness is also. Had the same issue ever since I replaced them the first time(no codes, but tuner said they didnt appear to be workin well, so I replaced them). Installed properly, and checked continuity in wire).
P0353 is Primary/Secondary IGN Coil Malfunction (C = #3). So is Cylinder #3's coil bad or wiring harness or something?
