Dyno results!!
Well i dont know this guy just met him today and happened to be there to dyno my car after his. The numbers are accurate look at my sig my car is a LS1 H/C car and with my mods i was hoping to do 400rwhp then again my shortblock is 130k. His car is a good running car i was impressed! Good job man dont let the envy of others spoil your hard work!!!!
thanks I am just glad that we now have another dyno verified option for off the shelf cams. I realize that it is blasphemous to utter the word cam unless it is preceded by custom grind but I am happy with the results out of a relatively small emissions friendly cam, maybe we can get the mods to update the stock head cam swap guide to include Lunati
Very nice numbers! Is this the .471/.480 lift cam? With the 1.6 rockers that puts it at .502/.512, making it significantly smaller than the hotcam.
Also, are you going to run it at the track?
it is .515/.530 with 1.5 so corrected to 1.6 it is .549/.565 and yes I will be going to the track but I have a driveline issue I need to work out and I need to get some DRs or something that will hook up.
Hmm, must be different from the cams listed on their website.
Some Nittos will do fine at your power level if you want to drive them everyday on the street. Good luck at the track!
Duration @ .050 is listed as 221/229. Did you change cams from the one in your sig? Just trying to figure out which cam you have since you made awesome numbers and I'll be looking into cams within a year
