Its almost time.
Its almost time.
I am kind of at a steeping stone right now. First time on the dyno the car made good numbers (i will post the dyno slips as soon as they are emailed too me) With a few changes in the set up to come some time early this spring and a little more tuning its going to be time to start thinking about the engine. My current set up is a nearly stock LS1 with stock TB and LS1 manifold. The only mods to the engine is a mild 228/232 cam and patriot gold springs. My goal is a safe and durable mild displacement set up cable of meting a 600 wheel goal with out going over board and braking the bank.
I should note the changes i talked about above will be swapping out the 60 trim to a larger compressor as well as going to a Air to Water intercooler set up. This should push the car into the low 500s.
Still not sure on the displacement or compression much less what brand and company to buy the internals from but this is just a general idea.
LS2 Block
Mild compression around 9.5-10.1 to 1
Mild stroke and bore with durability in mind.
The turbo will be something in the 72-80 range a big improvement over my over my limited 60.
LS2 Block
