can i use a truck flexplate
as title says can i use a truck flexplate im using an 03 lm7 engine and wondering if theres any issues with the truck flexplate and the fbody trans and converter.....
it kind of depends on which truck flexplate-i know the ones that used the 4l80e had a flat flywheel, with a spacer bet the crank & flywheel-this setup will also work with a 400, 350, etc trans
if the truck had a 4l60e, it may have the same flywheel as a pass car-it all depends on what the flywheel looks like
