y-pipe rattle?????
y-pipe rattle?????
ok guys i just got my headers finished up. and the y-pipe is a very close fit to the floor of the car. so when i give it very little gas or otherwise the motor torques up it rattles against the floor on the driver's side. its only sometimes at idle or under extremely light throttle. does anyone else have this problem. i want to say i can live with it, but i hate nosises that are not supposed to be there. Is there an easy way to fix this with out major work.
yes i have the pacesetter ORY that has the notch cut into it. and it is where its supposed to be. but its like my headers are tucked up more then they are supposed to be, but idk. everything else is fine. so idk really what is wrong. but i did get rid of my air pump and all the egr and emissions stuff, i know that doesnt make any difference. but yeh its like a kinda loud banging and rattle i guess u would call it. and its only hitting on the driver's side.
no i dont have an aftermarket tranny mount. and is there anyway TABBED 5.3 could you post some of the write ups or what you did to fix it. i was thinking about trying to get some kind of wrap and wrap it around it and maybe that will make it so its not metal to metal and therefore make it so i cant hear it. but idk im not sure. please any help any one can give me would be great. i am driving my car tuesday to get all my codes cleared and get all the emissions stuff tuned out of the computer. and then staurday im going to claymont delaware for the lsx meet and im taking my car down. so i dont really want to hear this rattle when im sitting at a light or something driving all the way there. thanks for any info.
ok guys i hate when people bump posts, But im going to do it cause i need help. PLEASE !!! i cant deal with the rattle. please help and thanks in advance. BUMP
Could possibly be your motor mounts are worn. I have shorty's with a slp y pipe, and my y pipe started hitting when I was letting out the clutch. I got some poly mounts, removed the drivers side and the mount was not broke, but the old rubber mount was half the size of the new poly mount. Since changing my noise has gone away. I had 204k on them so they were overdue. HTH
later
andy schuck
later
andy schuck
mine did the same thing. I have hooker super comp headers but mine was one of the primaries hitting up against the frame. It was one of the upper primaries and not the ones that are close to the ground. I had to remove my headers and hit on the frame to make clearence for the header so it would quit making noises. Not sure if that helps or not.
my y pipe lays down across the crossmember for the "tunnel".....only bc i didnt install the y pipe to the bracket on the passenger side bc i accidently through somethin away and havent had the motivation to make my own bracket
I had this same problem. I used some header wrap and simply wrapped the y pipe. You need two people. one to wrap the y pipe and another to pry the y pipe down about a 1/2 inch so you can slip the wraping around the whole pipe. two hose clamps to hold down the ends
OR
take off the y-pipe again and hit the top of the pipe more for more clearance
thanks for all the input guys. i used header wrap around the pipe and it somewhat went away. i just need to put a little more there and it will be completely gone. thanks for all the help.
