275s vs 285s, post pics!
Old 03-05-2009, 09:52 AM
fccs's Avatar
Default 275s vs 285s, post pics!
Anyone have more info on this subject? and if possible post pics as well. Basically some people say that 285/40/17 look a little taller then the 275s even tho they have the same sidewall height of 40 if im not mistaken? I wanna know if it would be worth it to do 275s up front and 285s out back or just stick with 275s all around. Would the 285 look any wider like some say, or would they look skinnier like some say. I plan to lower the car this summer as well so im not worried about the wheel space ugliness right now but what are your thoughts on these two sizes?
Old 03-05-2009, 10:09 AM
Spd-Kilz's Avatar
I think that the difference would be negligible. I'd go with whatever is cheaper. You'll probably notice more of a difference by switching brands (ie. Nitto to BFG), than you will be stepping up the size by 10 millimeters.
Also, be sure you don't throw off your ABS sensor if you're doing this!
Old 03-05-2009, 10:18 AM
fccs's Avatar
Ok nvm had a friend tell me I was doing it wrong and redid the math. heres what I got:
245/50/16 is 25.6inch tall
275/40/17 is 25.7inch tall
285/40/17 is 26.0inch tall
Old 03-05-2009, 10:28 AM
fccs's Avatar
Does anyone have any pictures though, I thought the 285s look pretty wide compared to 275s for some reason
Old 03-05-2009, 10:30 AM
Spd-Kilz's Avatar
Yeah, that seems about right. I doubt that will be enough difference to set off your ABS sensor. It's only about 0.3 inches.
I have a difference of 0.4 and I've never had a problem.
What wheels are you planning on going with?
Come to think of it, I would be inclined to go 275 all around, since you'll be able to rotate the front/back wheels&tires, since I'm assuming you're a little harder on your rear tires than your fronts.
Old 03-05-2009, 10:32 AM
03_r6's Avatar
I agree you might as well go 275 all around just for the sake of being able to rotate.
p.s. svt are you running 17/18 or did you snag the same size all around?
Old 03-05-2009, 10:33 AM
fccs's Avatar
Picking up 17x9 chrome firehawks. So just 17 all around for now.
Old 03-05-2009, 10:35 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
FR=275'S...REARS=285'S....My Kuhmo's are almost 1/2" wider in rear.[285's] [as far as ABS being screwed up--it takes almost an inch in height to do anything BTW.]
Old 03-05-2009, 10:45 AM
fccs's Avatar
nhr, do you have any pictures of that? I'm curious haha
Old 03-05-2009, 10:53 AM
Spd-Kilz's Avatar
17 & 18 staggered. It would be nice to go 18 all around though.
My M/T ET Streets set off my ABS sensor, but I'm not really sure how tall they actually are...
Old 03-05-2009, 10:54 AM
NHRAMAN's Avatar
Lightbulb
Not from rear...they are in sig though....
Old 03-05-2009, 11:21 AM
Eskimo's Avatar
If you corner aggressively and have some camber in the alignment, the tires will wear differently enough that rotating them front to back won't work worth a damn anyway...
I lost lots of front grip when i rotated mine after 5k because of the live axle/IFS wear difference. YMMV though.
Old 03-05-2009, 11:32 AM
fccs's Avatar
I wouldn't plan on rotating them if there a different size.. I only rotate tires when all tires are the same size, so if I got 285s id strictly keep them on the rear.
Old 03-07-2009, 05:28 PM
Bullet95z28's Avatar
I donthave any pics from the back with them on the car, but heres a few pics of my firehawks, 245/45/17 in front and 285/40/17 in back. These are the only pics of them on the car i have.
rear wheels
front wheels
Old 03-07-2009, 05:43 PM
i ran outside and took a few pictures of a 245/45/17 next to the 285/40/17 so you can see the height difference and width too.
Old 03-08-2009, 01:35 PM
coolformula's Avatar
275 and 285 are close and depends on the brand they could be really really hard to tell apart. I had 285's and I liked them it just saved me 100 bucks last time to get 275's and I didn't figure worth it for 10 millimeters.
but if the price is close go with 285's
Old 03-08-2009, 02:35 PM
fccs's Avatar
Alright I gotcha now, I'll just check the prices if there around the same ill just go with 285s.
Quick Reply: 275s vs 285s, post pics!
