proper lifter prep ?
Old 03-06-2009, 06:31 PM
blue99z's Avatar
Default proper lifter prep ?
I was always let them soak in oil for a day or 2 , but is that enough?
Can you prime them if so is it a pain ? I only ask because i had some lifetrs fail on me and find myself second guessing .....well myself . So any tips would be greatly appreciated . thx
Old 03-07-2009, 09:46 PM
sroach20's Avatar
i just soak for 24hrs and pop em in.
Old 03-07-2009, 11:41 PM
rosey's Avatar
I've heard you should soak them in mineral spirits for a minute or two and work all the rollers free before putting them into the oil to soak. I really don't know if this is necessary or not, can anyone confirm/deny?
Old 03-07-2009, 11:51 PM
sroach20's Avatar
they should always be cleaned with the mineral spirits. you really only need to dip the lifters in oil before you install them. i just do the 24 hour thing because i can.
Old 03-07-2009, 11:52 PM
01cherryreds10's Avatar
Do you need to use mineral spirits when installing new lifters?
Old 03-08-2009, 12:03 AM
sroach20's Avatar
you could probably use something else to clean them, but ive always trusted the spirits.
Old 03-08-2009, 01:18 AM
Notmyvette's Avatar
what's the point of the spirits? clean out the old oil? or is this for new lifters too?
Old 03-08-2009, 07:49 AM
vettenuts's Avatar
Morel specifically told me do not wash in mineral spirits or anything else. They are shipped with a heat sensitive grease that provides lubrication and washed out with hot oil. Preparation for installation may depend on manufacturer so I would use caution here.
Old 03-08-2009, 08:29 AM
LS1-450's Avatar
Soak in oil until they stop bubbling or overnight.
Old 03-08-2009, 08:32 AM
vsocks1's Avatar
Bob, so with new Morels you should just soak in oil and then install them?
Old 03-08-2009, 01:34 PM
burntblkZ's Avatar
I have a set of PBM lifters and they told me to put the lifters in dry to check what length push rod i needed for proper preload. Then it would be a good idea to pull the heads back off take the lifters out and soak them for a day then reinstall. I didnt like the idea of compressing my new head gaskets then taking them off and reuseing them so I got a pressure primer and pressureized my block to get oil to the lifters. Seems to work fine no problems so far.
Old 03-08-2009, 05:39 PM
Shawn MacAnanny's Avatar
For what it's worth my engine sat for 2 years without oil in it on an engine stand in my dining room and i didnt remove my heads to get to my lifters and they are fine. Perhaps you guys are only talking about new lifters?
Old 03-08-2009, 07:37 PM
vettenuts's Avatar
I soaked the rollers and worked some oil into them per Morel. Then I dipped them prior to installation and coated the rollers with Redline Assembly Lube. I didn't soak them.
Old 03-08-2009, 11:06 PM
sroach20's Avatar
why would it matter if they are dry or not. your not supposed to extend the pushrod checker enough to push down the lifter.
Old 03-08-2009, 11:22 PM
blue99z's Avatar
awsome thx for the replys guys
Old 03-08-2009, 11:39 PM
elias_799's Avatar
if the engine will be sitting for a while with the lifters, wrench on the crank pulley and you will get some oil in the lifters pretty soon.
Old 03-09-2009, 01:06 AM
Droptopws6's Avatar
I soaked mine in oil until the bubbles stopped wasnt very long. My valve train is quiet.
Old 03-09-2009, 04:43 AM
vettenuts's Avatar
One example would be to follow Katech's procedure, where the preload is set by measuring from the point where the plunger bottoms in the lifter.
Old 03-09-2009, 10:07 AM
sroach20's Avatar
got a link to the write up? just curious to see whats involved.
Old 03-09-2009, 10:44 AM
LS1-450's Avatar
Lifter prep is a different subject than pushrod length checking. The best way to check pushrod lenght is to use a non-compressable lifter. The internal spring can be removed from an old lifter & then fill the void w/ a nut & some JB weld or just about anything that will fit. Once dry, there is a lifter that will not compress & can be used for measuring pushrod length.
Quick Reply: proper lifter prep ?
